Anyone know if it's possible to paint a bike with this?
Re: Vantablack [caffeinator]
In case anyone is wondering what it is https://www.surreynanosystems.com/...ack/vantablack-s-vis
I am pretty sure it is possible, might be a little expensive though. However you might feel disoriented riding a bike painted with it.
It would be cool on a disc...just a gaping maw of a black hole.
There are other companies that make other similar products as a sticker. It may not be 99.96, but its close enough that you can't see reflections, thus contours.
Re: Vantablack [dfroelich]
Where can you buy the sticker version?
http://www.acktar.com/
By the way, it isn't cheap!
That would be hilarious. Never mind me riding a black hole.
Here's a basketball painted with vantablack:
http://i.imgur.com/19YYs7h.jpg
Looks like a photoshop right? It isn't. Edit: never mind. Bryan's article had the same picture.
caffeinator wrote:
Anyone know if it's possible to paint a bike with this?That would be awesome but I think the light absorbing properties are damaged with any contact or abrasion.
dfroelich wrote:
It would be cool on a disc...just a gaping maw of a black hole. There are other companies that make other similar products as a sticker. It may not be 99.96, but its close enough that you can't see reflections, thus contours.
Even better, add some spirally swirls around the edge.
The fine nanometre-sized optical cavities that make Vantablack S-VIS so dark mean it cannot be used in environments open to direct contact and mechanical abrasion. It needs to be protected from accidental touching, for example behind or inside a component, or situated where contact is avoided.
