I agree the Park Tools tension meter isn't that great, what you're describing can happen. I saw it recently when mounting super tight TCS beaded WTB tires to a pair of Stan's Crest wheels (yes, they aren't supposed to be compatible). It dropped the tension noticeably and the rim went a couple mm to the side as well. They had been tensioned not terribly long before and hadn't budged much out of true since. I just re-did them with the tire on (and inflated) and went from there. No problems in the 8 or so months they have been on. I'm really not sure if taking the tire off would create over-tensioned spokes and create a crack in the rim bed (like what Chris was referring to). I had never thought about that until now! I can't say I have experienced it on a road rim, but I haven't felt/seen anything weird enough to ever check for a tension drop.
I don't consider myself a good wheelbuilder and clearly don't own a wheel company, but abhor paying a shop (and waiting) for such mindless work and learned a bit about wheel building and maintenance. I would guess there wasn't much stress relief done during/after the initial build. Can you take us through what you did for that?
The DS and NDS shouldn't have the same tension on most builds. An offset rim can help even the tension slightly or a 16:8 build (16 spokes on the DS and 8 spokes on the NDS) gets the tensions pretty even.
I may have missed it above, but Roger Musson's book is great. There's not much you need to know that isn't in it.
