Any FM086 owner here?
If so, would you check the maximum height for a 54 size?
Other useful info are SEAT TUBE LENGTH (center-end) and SEATPOST LENGTH...
Thank you in advance!
76cm from the seatclamp to the height of the bottombracket. measured straight to the ground. And a couple mm more than 78cm measured straight from the BB to the clamp (highly dependent on where the clamp is relative to the seatpost)
56cm seat tube length. Didn't bother to completely remove the seatpost.
SkippiTT: Mar 17, 17 7:13
Thank you!
My goal is to reach 1.83 cm from BB center to SADDLE top on a size 54 FM086 I'm about to buy.
Here's my calculation, according to what I've found on the web:
SEAT TUBE (center-end) = 54,2 cm
SEATPOST (30 cm overall, with 7 cm inside the top tube) = 23 cm
SEATCLAMP = 2 cm
SADDLE = 4 cm
Sum is 83,2 cm and it would be fine but...
... unfortunately it's different from both your data and the seller's ones (I'm afraid they're both more correct than mine, even if I don't know where i'm wrong)...
Joe73: Mar 17, 17 11:03
