The problem must be the cables because if you use them contrary to their design they don't work as advertised ????
Mine show NO fluffing.
I may take some pictures for you.
The friction dropping ability of these cables is not diminished by stripping off some of the coating near the end.
So if you continue to use them incorrectly, why not just strip off the last 50mm and still retain the benefit of lower friction throughout the rest of the cable?
This clearly demonstrates how these cables get a bad rap.
People just don't use them as recommended.
People go to all sorts of lengths to get good cable runs when all you have to do is cut the casing with proper tools, open out the inner liner, grease cable and fit.
It's so simple any idiot can do it but seems that nobody believes that something that simple and easy to do will work so they decide to improve the system by using lubricants that are not compatible with the coating or none at all.
These cables have little tiny ribs for the entire length of the cable to hold the special grease that is very reasonably priced.
It is a system.
But nobody uses it like that and wonders why they have issues.
Stay tuned for the next exciting topics of:
My Shimano brakes don't work like they should but I'm sure that it is nothing to do with using DOT fluid in them.
My swimming is shite but I am sure that it has nothing to do my ignoring my shite body position and it must be because of
(insert latest hairbrained popular theory/excuse due to my late onset swimmers disease.)
It is a system.
