johan123 wrote:
gary p wrote:
johan123 wrote:
I swim 5x a week now, about 15 km in total.
Should i add an extra session (will be a double day) or increase the distance on some of the sessions? Does it matter?
Im quite explosive and does lack endurance.
Thanks
What's your goal?
What's your typical training session like now?
You say you're explosive, but lack endurance. Can you quantify those two statements? How fast can you swim a 100, and what's your time for a longer swim (800/1000/1500/1650)?
good questions! my normal session now is like 1000 m warm up, then something like 7x200 m or 10x100 m and then some pulling untill 3000-3500 m. Sometimes main set is 10x200 m zone 2.
I have no new data on anything else, I would go sub 1.20 for 100 m I think. 50 m I have done at 37 s in some set. Maybe I can get down to 35-36 (not diving) doing max.
Let me start by saying that I think 5 x a week, +/-3k per workout, is plenty enough time in the pool to reach just about any goal short of becoming an elite level competitive swimmer. So, to answer your basic question, no, you don't need another session. You need to structure your current sessions to be in line with your goals. So we now have an idea what your workouts are like, and we have some baseline measurements for sprint speed. But your goal is still vague. It seems you want to improve your improve your endurance, but how would you quantify that goal?
To help you in establishing reasonable goals, here are some rough ideas of how that 100 speed of 1:20 should project out over longer distances:
200 = 1.12 x 100 speed = ~1:30/100
400 = 1.22 x 100 speed = ~1:38/100
800 = 1.30 x 100 speed = ~1:44/100
1500 = 1.36 x 100 speed = ~1:49/100
If I were to have to give a suggestion based on what little info you've given, it would be to do a 2000 yard set, 3 times a week, at that 800 pace. Maybe, to start, you have to do 40 x 50 on a 1:10 interval, with a target time of :52. The idea is to swim as close as possible to :52 every time. Doing the early ones at :48 doesn't really help if it means you can't hold the :52 target time later in the set. Consistency is what you're after....besides building the actual physical endurance, you're trying to build muscle memory of swimming at that pace. Now, if you miss an interval, you skip the next interval to rest. It's better to rest a little, then resume swimming at the targeted pace, than to continue swimming slower and slower because you're exhausted and can't hold good technique.
If you miss the interval 3 times before getting to the 2000 yard mark, you stop. Do an easy 300-400 recovery swim/set, and move on. Try again next workout.
If you can get all the way to the end of that set, or even close (say 32 reps), you can add 26x75 to the rotation. Same pace, rest always in the ~20 second range. So you'd be on a 1:40 interval, with a target time of 1:18. Same rules for failure to make the targeted pace.
Once you're getting to the end of that set, or close, you can start adding 20x100 to the rotation, interval 2:05, target 1:44. You can also try to do the 75's on a 1:35 interval instead of 1:40.
If you can do 20x100 at that pace, or even 16x100, I guarantee you can swim an 800 straight at that pace. There will be carry over effect up and down the distance scale, as well. Your capacity in the 400 and 1500 will improve similarly to your improvement in 800 capacity. Once you've "mastered" a pace on the 100's, you increase the pace and start the process over.
Speaking of 400 and 1500, that's what I'd work on the other two days. 20 or 25 x 50 at 400 pace (similar rules for interval, target, failure) one day, and a 2400-3000 yard set at 1500 pace the next (like 24-30 x 100 or 16-20 x 150).
Other Suggestions:
- I'd shorten the warm up. I do 500-600 yards, then get right into the race pace stuff.
- Pick up another stroke to work on when you've exhausted your freestyle capacity for the day. You're better off doing a small set of quality breaststroke or backstroke at the end of practice, than swimming some ragged, slow freestyle
- Time trial yourself occasionally. Know what you can do for a maximum effort swim across a range of distances, so you can verify whether or not your workouts are actually helping you improve.
[EDITED to correct pre-coffee math errors]
