What is the potential for shifters or derailers or any other components of a DI 2 set up to wear out and how often does this happen
Re: How often do di 2 components wear out [Fishbum]
Same as mechanical.
Re: How often do di 2 components wear out [jimatbeyond]
So you could potentially be replacing di two components on a yearly basis?
Fishbum wrote:
So you could potentially be replacing di two components on a yearly basis?- 105: Shifts decently, lasts about 1 year of heavy use (~5,000 miles, starts to show wear), heavy
- Ultegra: Shifts very well, lasts forever, still a bit heavy
- Dura Ace: Shifts perfectly, lasts forever, light
I have mechanical Dura Ace on an old road bike with >>30K miles and it is still going strong. I started to bump into the wear limits of new 105 after a few thousand miles (more dropped chains and shifts began to lose cripsness).
The DI2 specific components that will see wear are the shifters and the derailleurs. I'm not sure I've known anyone wear out a shifter - much more likely to get damaged through accident or neglect.
FD has little to wear out, rear you can wear jockey wheels but these are easily / cheaply replaced.
My 2012 ultegra DI2 bike has probably 20k under its wheels - still on original battery, shifters, cables - front junction box has been changed but that's upgrading not because there was anything wrong with the old ones - derailleurs are original with new jockey wheels on the rear. Obviously chain, cassette etc have been replaced but that's the same cost / parts as a mechanical system.
Ultegra and Dura-Ace shifters and derailleurs should last 20,000 miles.
jimatbeyond wrote:
Ultegra and Dura-Ace shifters and derailleurs should last 20,000 miles.Do you sell SRAM?
The only component I ever needed to replace was a FD that broke on the hinges, but it was still under warranty. I've got an Ultegra Di2 6770 system still going strong after 20K miles! I honestly have had more wear and tear (and breakage) with mechanical systems than Di2.
"Most of my heroes don't appear on no stamps"
Blog = http://extrememomentum.com|Photos = http://wheelgoodphotos.com
Every once in a while.
Fishbum wrote:
So you could potentially be replacing di two components on a yearly basis?Cripes, how much riding do you do in a year????
Re: How often do di 2 components wear out [exxxviii]
Are you referencing the wear components, such as chain, cassette, cables, chainrings, or the shifters/ derailleurs?
Re: How often do di 2 components wear out [FishOutofWater]
Re: How often do di 2 components wear out [walie]
walie wrote:
I'm merely trying to weigh the pros and cons of di2 versus a mechanical build. And figuring in long-term costs as part of that
In a few years, you will want Di3.
Lol
My RD cogs were pretty worn after 4 years. That's it. Well... they still were probably fine, but I replaced anyways.
Other than that, I just did the usual chain and cassette replacements.
The RD and FD shift like they were new. My shifters are in great condition.
Might need a new battery one of these days, but I still seem to get a couple months off of a charge so...
have about 15,000 miles on a 2013 Giant TCR Advanced with Ultegra di2 10sp. Still on all the original parts.
exxxviii wrote:
- 105: Shifts decently, lasts about 1 year of heavy use (~5,000 miles, starts to show wear) ...
Re: How often do di 2 components wear out [BrianB]
BrianB wrote:
I wouldn't consider 5k miles in a year to be "heavy use". A cyclist who averages 12 hours a week -- not a huge amount by any stretch, would be around 10k miles per year. At that level I would not expect to replace even 105 components every year.
What makes you think its worn? Sloppy shifting?
exxxviii wrote:
BrianB wrote:
I wouldn't consider 5k miles in a year to be "heavy use". A cyclist who averages 12 hours a week -- not a huge amount by any stretch, would be around 10k miles per year. At that level I would not expect to replace even 105 components every year. Heavy use is a very broad range. And yes, I would expect a dedicated cyclist riding 12 hours/week to burn through 105 gear. I was surprised with the wear on my 105 after around 5K miles (~6 hours/week training for HIM). After talking to a few bike shop owners, the collective opinion I found is that 105 is probably good for about 5K miles.
Try cleaning your drive train more than once a year and stop visiting bike shops run by scam artists.
Not counting cassettes, the only meaningful difference between Shimano's top three groups, both road and mountain, is weight. Dura Ace/XTR is less durable because of the titanium used for cassettes.
Maddog23 wrote:
What makes you think its worn? Sloppy shifting?I am a pretty excellent bike mechanic, and no amount of adjusting, cleaning the drivetrain, or new chain fixed it.
Arch Stanton wrote:
Try cleaning your drive train more than once a year and stop visiting bike shops run by scam artists. Not counting cassettes, the only meaningful difference between Shimano's top three groups, both road and mountain, is weight. Dura Ace/XTR is less durable because of the titanium used for cassettes.
