Bobby Sweeting wrote:
As I mentioned earlier in the thread, no, we have not been present at any of the test facilities. But the fact that we haven't been present does not mean we can't analyze the data against our theoretical CFD models. I've also been in the wind tunnel, including A2 and MIT, more than I like to remember, both as a pro racer and frame designer. I have no personal desire to go back, I just want the results! Haha.This perspective strikes me as bizarre. Every manufacturer I interacted with in the recent Aero Shootout/AeroCamp insisted on being there while their equipment was tested -- which makes complete sense, given how sensitive these tests are and how dependent the results are on executing those tests properly. Without having been there for the testing, there's no way I could adequately interpret and model the output data -- and I'm talking about a very simple quantitative task (yaw-weighted drag, etc.) relative to the one you are describing. So again -- and please forgive me as I know this question has been asked -- but I am still having a lot of trouble understanding how you took Cody's results (or Joe's, or Maggie's) and validated your CFD models, or even evaluated those results vis-a-vis any CFD model at all.
Here are your words.
We looked at generalities when it came to turbulence, vortices, low pressure pocket locations, etc on the frames that we have experience with. The goal was to find patterns and create a nice average that we could simulate while designing our disc. This is precisely why I mentioned that no wheel will have the "best" aerodynamics no matter the situation. It's very situational. We did our due diligence to design a wheel that would have an optimal shape in the majority of situations based on the knowledge we had with a variety of frames.Note: generalities, patterns, average, simulate, situational, optimal, majority, variety -- these are all vague and cheap words. Brian is right that specific words have specific meaning, but these words don't really mean anything at all . If we're talking about a matter of maths and science...well, here's an idea: can/will you share some numbers? Can you show us a spreadsheet or workbook? Can you break out the calculations you made, or tell us how they were made? What software did you use? Who did the modeling? How specifically did the output data from these athlete's test influence the model, and which variables were most meaningful in your design heuristic?
I think all of us (at least initially) appreciate you coming on here to field questions, but so far this hasn't gone very well for you or left anyone with a very good impression of your brand or your product. So if there is substance behind your words, please show us. This is an exceptionally analytical crowd you're talking to, and we can handle the science and much prefer it over your jargon.
Failing that, I think the presumption has to be that there is essentially nothing quantitative behind this design, except maybe the dimensions and the weight. Which is fine too, because it still looks like a great product. It's made of carbon fiber; it's toobless ready; it's impressively wide (and set up toobless, likely very comfortable); and it's probably pretty damn aero. Believe it or not, that's plenty impressive for me and likely for many others. What's incredible unimpressive -- and frankly, downright unacceptable -- is your apparent attempts to claim that this product is the output of work you simply did not do.
