Beware veloplugs and the like with very light aluminum or carbon wheels. 9 out of 10 latex flats (that are not related to installation errors..which are probably the 9 out of 10 initial latex tube issues) in my experience have been due either to an extreme heat event caused under heavy braking, or caused by degradation of the tube caused by heat cycling while braking. If you pull your latex tubes and they are rippled or wrinkled..then you have heat damage and the solution is MORE COWBELL.. or actually TAPE.
Tubeless tape works well as it is both thin and smooth which helps with installation of the tire as it helps prevent pinching. It also helps slow the heat transfer from the rim to the tube..so think of it as a sort of insulating layer that is buys you time. On a test machine, a good rim tape can double the amount of time under extreme braking it takes to flat the tube.
What I'm saying here is that even if you use the plugs..you should use tape...
Gorilla tape will work, but it is both thick and a bit sticky, so save that for tubeless use as it will increase the likelihood of installation issues.
And to continue beating the drum.. YES to racing on latex and yes to keeping butyl as your spare.
Josh
http://www.SILCA.cc Check out my podcast, inside stories from more than 20 years of product and tech innovation from inside the Pro Peloton and Pro Triathlon worlds!
