Funny you ask, because I've been experimenting with this in the pool lately. It also sounds as though we have some similar bio-mechanical issues. GreenPlease best described what I have found:
Quote:
Her core is engaged to flatten out her low back which would normally result in anterior tilt *but* her glutes are also engaged which pull her legs up high in the water
I'll describe as best I can what has helped me (an adult onset swimmer). Instead of focusing on "butt up," I concentrate on 1) bringing the small of my back to the water surface using deep core (not surface abs) to "roll up" my pelvis (think "noon" on pelvic clock)--the small of my back doesn't actually break the surface; because I tend to be swayback in the water this actually puts me in a more neutral position; 2) getting my feet to the surface of the water by lifting with the back of my leg/hamstring--that requires contracting glutes; and 3) keeping neck aligned/not slouching so that water hits just above my eyebrow--I tend to submerge my head like a submarine in an effort to get my back neutral.
One of my "aha" moments was that, at least for me, effective kicking was more about "pulling up" than "kicking down."
On sets of 100 and longer in a 25m pool, 1st length I concentrate on body position as described above; 2nd length I concentrate on exhaling as much as I can--I tend to hold my breath; 3rd length concentrate on body position again; 4th length concentrate on getting fingers/lower arm pointed down before pulling (EVF).
BTW, I think the "butt up" is a red herring. My conclusion is that many swim/tri coaches are so used to teaching swimming to lean runners with sinking legs that when they see butt up and feet breaking the water, they assume that the body position is good.
YMMV.
No coasting in running and no crying in baseball
