So I'm trying to set up my new SRAM Etap aero kit. All parts are new. I set up all of the limits etc etc. Put on the chain. With every crank rotation there is a slip that occurs on the small chainring, like the chain is riding on top of the chainring then it plops back down at the end of the rotation. I thought it I installed my small ring backwards and switched it around and same thing. I played with the B tension screw etc etc. I have good tension on my chain. I just can't figure this one out.
Can you help?
Could it be a bent der hanger? I'm just clueless at this point.
Can you help?
