kgro wrote:
From my limited understanding of how BBA works, this is what the packed bike looks like:
and this is Omni
I have marked with red arrows places on the frame, that Omni, or Ventum won't be able to offer for fastening (no downtube, huge toptube, huge flat area instead of seat tube). So effectivley the only places avaliable for fastening would be one side of a fork and a chainstay. Not a great tradeoff in terms of safety of transport with the Scicon in my opinion. Unless I am wrong about how BBA works, of course.
By the way, does the BBA also take disc wheel?
I have a Bikeboxalan which I have used for multiple flights, short haul and long haul. I highly recommend it.
Something like the Omni would be a problem though, because the Velcro straps would be too short to go round tubing of that width. But if you could find some fabric which had one sort of Velcro on one side and the other on the reverse, you've got an instant extension strap and should the able to secure the top tube and down tube.
It takes a disc wheel fine; you just have to leave out the anti crush pole. Which on the first trip leaves you a little anxious, but it's really not an issue. I've probably done more trips without the anti crush pole than with and never had a problem.
It's biggest drawback is gettnig an aero cockpit in it. For road bars I take the stem off the steerer and that's it. Really easy. But for aeros I have to do that, and take the aeros completely off the base bar. I now mark the positions of everything with tape before I take it to bits, which aids the re-assembly considerably, but it's a bit more of a PITA, especially considering how tight the bolts on the aeros have to go to stop them slipping.
Roadie is a 56cm Cervelo; tri is a 54cm Cervelo. Seat tube has to come out of the tri bike only because I have cages behind the saddle which are too wide to allow the box to close. It sits where the helmet is in the pic (where the box is deepest).
