So my x360 has packed it in as it won't charge and now it's dead flat. I checked the charger with a voltmeter and it reads 19 odd volts at the connector pin.
I've heard quite a few say this is a MB issue and to replace that will erase all SSD content. People on forums have said to remove the drive, copy content then send it in. Apparently it can be formally done without voiding warranty if done with care.
So having removed the back plate (and slicing my finger pretty good in the process!), which is the SSD? The IT guy at work said depending on the type of drive it might not be possible.
Can you tell from this pic?
Alternatively Can I remove the battery to charge externally?
