longtrousers wrote:
Sean H wrote:
I appreciate you doing this but your times are wildly inconsistent so I'm not sure how much we can learn from them other than the swimskin is faster than a speedo. You really need to be coming in within a couple of seconds on these 400s to give confidence that you're swimming the same effort across all of them.You can see a generally improving trend over the season and the swimskin times are significally below that trend, at least to my opinion.
@Thomas Gerlach:
I do my 400m always with the same intensity, let's say at 95%. I tested only with the kiwami. I'm going to race my planned IM with a 2-piece bike wear (Castelli Stealth) which I thus will wear under the kiwami. Of course I will test this too, but I can't see any problems with that, especially because I will still loose a couple of kg until summer.
Sean, Thomas, I can understand if you can not take any conclusions from the data. I just wanted to share it, and as I said, to me there is a clear trend of 15s on 400m (or let's say 10-20 s).
Maybe I will do once a test on one day with e.g. 10 times 200m with alternately swimskin/speedo, but that's a lot of work putting the swimskin off and on ...
So I understand you are just trying to see a trend of improvement, but it would still be helpful to see how much you are varying in the days. If you are doing one 400x95% you should be able to do 4 reps at 95% or even 8 reps a day. Regardless, the important thing is that you test a tightly fitting tri kit that you will be wearing for racing. Skin is slow, we know that. 2 pieces are slow, we know that. If you are really set on a 2-piece then ok but I assume you are doing this testing because you want to go faster?
If so you might want to try getting a snug 1-piece and testing it straight up, versus the suit + the swimskin. Regardless thanks for your n+1 testing.
