tessar wrote:
ridenfish39 wrote:
I will never get why the P4 is supposedly so fast with 2 brakes and cables hanging out in the wind. So, if Cervelo made a hidden brake and cable version of the P4 it should be the fastest TT bike of all time........
The cynics would say: I don't know what the P4 has hanging there in the wind, but "braking" wasn't part of the job description.
Braking workedish sorta. For most tris the braking was fine. If I was doing boulder Peak on it I would probably be a bit sketched out on it considering I went off roading once and can easily hit 50 coming down old stage. Also I was using the original Ventus which were basically razor blades for brake levers.
But it was a great bike. I cut a hole in the side of the waterbottle and used it for spare tire and flat repair storage.
The big problem with that bike was the release right in the middle of the introduction to wide wheels. It was very hard to get anything besides a flat disk to not rub in the back. But over all loved the bike.
And the first year had the cracking issues behind the seat post. But that was fixed in the newer version.
To the OP: do the 5-3's have the hydraulic brakes? If so I'm not sure how you don't like those. I've been on DA, SRAM, Tririg and these are by far the best brakes I've had. I would put them on my road bike if I could.
I love the p5-6, but it is a highend race bike. You have to expect it's going to be a bit more work to maintain then a p3 from 2006.
