I currently zip tie it, is there a better way? It sometimes shifts a little messing with readings. It's the magnet that comes with a Garmin speed and cadence sensor.
Re: Garmin crank arm magnet [EnderWiggan]
This is my setup :
WD :-)
WD :-)
Re: Garmin crank arm magnet [WD Pro]
Omg amazing! How did you do that?
It's just an eBay magnet on the end of the pedal axle and some satin vinyl for asthetics / keeping the sh1t out of the hole :-)
WD :-)
WD :-)
Awesome, for some reason my brain never thought to think of using other magnets.
The Satin Vinyl looks pro!
Thanks
WD :-)
Thanks
WD Pro wrote:
It's just an eBay magnet on the end of the pedal axle and some satin vinyl for asthetics / keeping the sh1t out of the hole :-) WD :-)
Looks like you got your solution.
An alternative is ditching the magnet sensor altogether and replacing it with accelerometer sensors:
https://www.amazon.com/...s=garmin+bike+sensor
No magnets, on the crank or the wheel.
EnderWiggan wrote:
Awesome, for some reason my brain never thought to think of using other magnets. The Satin Vinyl looks pro!
Thanks
FYI, instead of an eBay magnet, search on amazon or the likes for a 1/2" N42 rare earth magnet. I originally bought one of these that was branded as a low profile cadence magnet: http://www.amazon.com/gp/product/B0085N7KDY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Turns out there were exactly the same as the 1/2" N42 magnets that I purchased later on (for a make my own fridge magnet project). I found that out when I lost one and saw that those magnets was pretty much the exact same size. (lost it due to it sticking to another piece of steel on my under BB stand that I use to lube my chain...inside crank arm got a little too close to the metal arm of the stand when I was setting it up).
Buying a 10 pack of the N42 magnets is about the same price as the 1 that I listed above. Works the exact same. Nice part is it is a solid piece so it will cover the pedal hex cavity so no need for another cover.
Yeah to be fair I just bought magnets of the correct diameter from eBay so they fit well - and then covered it up anyway ... lol
Since been swapped for a thinner type as I swapped pedals and the axle was a bit longer on the new ones :-)
WD :-)
WD :-)
