You are looking at a handmade Mosaic RT-1 titanium disc brake road bike frameset with an ENVE RD disc fork, Chris King headset and Chris King bottom bracket.
The frame has been ridden less than 300 miles! Mosaic will back this frame forever! The RT-1 presents the best of what Mosaic has to offer with it's roadbike lineup. The lightweight 3/2.5 double butted titanium tubeset means this bike equipped for anything.
The Mosaic RT-1 is a performance bred piece of equipment that knows no limits. A particular blend of oversized double butted and thin walled straight gauge tubes makes a responsive handling characteristic without losing the quality ride titanium frames are known for. The RT-1 is Mosaic's flagship road model and this one is set up for mechanical shifting and post mount disc brakes. The top tube had internal cable routing for the rear disc brake and looks so clean.
This frame was handmade by the fine folks at Mosaic Bicycles in Boulder, Colorado
It was built for a rider who is 5’9” and has a 31” inseam. This rider typically rides stock 54cm road bikes
When this bike was built the rider had the saddle at a seat height of 72.5cm from center of bottom bracket to top of saddle.
The rider also used a 100mm stem with - 6 degree rise.
BRAKES: disc, post mount
Quick release dropouts on front and rear.
See the geometry specs in the photos.
MSRP on this when it was new was $5000.
http://www.pbmcoaching.com
USA Triathlon Level 3 Elite Coach
USA Cycling Level 1 Elite Coach
