Re: Ingenious mechanical hack-jobs [DarkSpeedWorks]
Re: Ingenious mechanical hack-jobs [speed856]
Brilliant! I need to make one of these now.
"Always race like you're in contention for the podium"
I post bike related projects to Instructables. Check it out.
https://www.instructables.com/member/SCHLEPIC/
Hello Slowman and All,
If you use an aluminum valve extender on your disk tire .... you can bend the aluminum valve extender about 45 degrees in a smooth curve so it is easy to inflate with regular tire pump chucks.
I had to try the bend a couple of times ... putting the valve extender in a vise and using pliers to bend ..... and I broke one extender on the first try .... but once done it is easy to repeat and makes inflation a no two hander no brainer .... .
Cheers, Neal
+1 mph Faster
Cheers, Neal
+1 mph Faster
