I have a 2015 Felt B14 that has the rear brake mounted at the bottom bracket. After using the bike outdoors for one season I noticed that the rear brake was not working effectively. Upon further investigation I realized that one arm of the caliper was barely moving and lacked the release and spring back like the other arm. While removing the brake from the bike, the arm that was not working properly came apart and the brass bushing it rotates around was stuck (corroded) onto the post it mounts to. I lubricated and reassembled it with some improvement but it never performed with the same functionality it originally had. After a season of babying this along I’ve decided it must be replaced.
The bike came with the TRP 922.1 brake (shown below). This brake mounts on two posts (bosses) on the frame that have small holes for the spring to coil against. When it worked properly it did offer good stopping power but in my opinion lacked ease of adjustment when shifting from wide rim to narrow rim wheels. Before replacing it with another TRP brake I wanted to see what other options I might have, especially with improved adjustability. It looks like the TriRig Omega X or SV (if I can find one) would be options but at a significantly higher price. I’m not familiar enough with the Shimano line to know if they offer a design that would work with this mounting system or if there is something else I should be considering. Any experience, thoughts, or opinions would be appreciated before I replace this brake.
Thanks
Roger
