dontswimdontrun wrote:
Cool, more data :) Some observations:
- Size Large should be on the line with elbow at 640/425, your CTT line goes through 640/485, so elbow to pad centre is 6cm? That's certainly less overhang than I choose, and I think Steve too.
The SC pads are roughly 80mm front to back and our Fit Services classes use the elbow just off the back of the pad as a starting point (based on user surveys as well as observations of what users bring in as their existing setups). Also keep in mind this convention is geared towards (and based on data from) the much larger tri contingent vs the smallish TT crowd (and considerably smaller still CTT-governed TT cohort).
- Admit I'm a bit confused by the mid pad / pad range / full range terms, note that the XL cut-off (short) ties in with the shortest full range number.
Explained here.
For completeness the full quadrilateral of pad adjustment for each size with "CTT line" across the middle would show how the riders fit in (or don't). or just back out from our fit charts and what's pictured that the actual leading edge of the pad reach range is ~90mm to the right of the CTT line (pictured leading edge).
Carl Matson
