Bleucheese wrote:
GreenPlease,
My sincere thanks for your response.
There are a few reasons I steer clear of lessons. i guess the main one is I've seen my
friends take many many lessons, and never really improve. Plus I see lessons going on at the range, and I have no confidence in what I hear from the "pros".
The obvious answer is to play more. But that's true for any sport, and I only have limited time to dedicate to golf. But I do like to swing the club in my backyard, and if there are tools or aids that helps, I'll give them a try. I think all of the aids you listed are worth looking into.
The weakest part of my game is the approach shot. I am usually in the fairway off the green, my chipping and short game is top notch, and my putting is above average. My approach shots are inconsistent since off the fairway I am the guy who
hits the ball first, not behind the ball taking that clean divot the real golfers take. Which means I hit it clean, top it, or hit a big clump of earth behind the ball. Changing my long irons to hybrids helps a little, but mid irons are a crapshoot.
The device in the sharper image catalog looked so promising, it is a thing that attaches to the club head. I had expectations it would tell if my clubhead was not square at impacts, or my swing plane was off line during the back swing, or whatever. That would be very helpful intel when I'm just swinging the club in the yard. Don't always have time to go to the range. I have heard no reviews on this product, so I quess it falls under "gadget".
Thanks again.
That's because many who take lessons expect the improvement to happen immediately. The only path to improvement is practice but what to practice? Further ingraining bad habits makes them harder to break once you know what the problem is. Find an instructor who can work with you on one aspect of your swing. You indicate it is inconsistent ballstriking. A good is strike is ball first then ground. A perfect divot occurs after the ball is struck and should be in front of the ball. A trained eye could determine why your contact is so inconsistent. Improving contact and eliminating a two way miss are two of the most significant ways of lowering your score.
A false humanity is used to impose its opposite, by people whose cruelty is equalled only by their arrogance
