trail wrote:
Tom A. wrote:
Calibrate? No.
Zero the offset? Yes.
(There's a difference, despite Garmin's misuse of the term "calibrate")
"Zero early, and zero often"...and with your Riken, you can zero anytime while you're riding just by backwards pedaling while coasting :-)
I'd consider them both forms of calibration. In both cases a parameter is being calculated based on comparison of a measurement to a known quantity. One is a zero offset calibration, another is slope calibration.
I think of it more as a power meter is basically a fancy mobile weight scale. Setting the zero, or tare, is easy to do and check. Making sure its output is "calibrated", takes more time and a series of loads.
Complete calibration requires BOTH. To call zeroing "calibration" is being incomplete.
Garmin could have used the term "tare", or "zero" instead of calibrate for the offset zeroing process. That would have saved a TON of confusion when people are asked if they are using a calibrated PM, and many answer "Sure, I calibrate it before every ride" :-/
