FS: 2016 Sworks Roubaix 56
This bike is mechanic owned so it is in imaculate condition and has been regularily maintained. Below are all the specs for this bike as it is all stock. PM me with any questions!
Asking $6800CAD. The bike will be professionally boxed for the buyer.
The S-Works Roubaix SL4 Disc Di2 was born from the cobbles. With multiple Paris-Roubaix victories, not to mention countless other wins on some of the roughest roads professional cycling has to offer, the S-Works Roubaix has proven itself time and again as the gold standard of endurance race bikes. Featuring the exclusive S-Works SL4 FACT 11r carbon frame and fork and the legendary performance of the Shimano Di2 electronic build kit and hydraulic disc brakes, the S-Works Roubaix SL4 is the ultimate in race-proven performance.
FRAME
S-Works SL4 FACT 11r carbon, FACT construction, shaped/tapered 1-1/8" to size-specific lower head tube, compact race design, Zertz, internal cable routing, carbon OSBB -
FORK
Specialized FACT carbon, size-specific taper, disc mount -
HEADSET
1-1/8" upper, size-specific lower, stainless steel cartridge bearings, carbon top cap -
STEM
S-Works SL, alloy, 4-bolt, 6-degree rise -
HANDLEBARS
S-Works SL Carbon, shallow drop, 125mm drop, 75mm reach -
TAPE
Specialized CX Pro, w/ sticky gel -
FRONT BRAKE
Shimano BR-785, hydraulic disc, Ice-Tech resin pads w/ fins -
REAR BRAKE
FRONT DERAILLEUR
Shimano Dura-Ace Di2, 11-speed, braze-on -
REAR DERAILLEUR
Shimano Dura-Ace Di2, 11-speed -
SHIFT LEVERS
Shimano 785 Di2, 11-speed -
CASSETTE
Shimano Dura-Ace, 11-speed, 11-28t -
CHAIN
Shimano Dura-Ace, 11-speed -
CRANKSET
S-Works FACT carbon, 50/34T -
PEDALS
Nylon, loose ball bearings, w/ reflectors -
FRONT WHEEL
Roval Rapide CLX 40 Disc SCS -
REAR WHEEL
FRONT TIRE
S-Works Turbo, 120TPI, folding bead, BlackBelt protection, 700x26mm -
REAR TIRE
INNER TUBES
Ultralight, Presta valve -
SADDLE
Body Geometry S-Works Phenom, carbon rails, 143mm -
SEATPOST
Specialized CG-R, FACT carbon, single bolt, 27.2mm -
SEAT BINDER
Alloy, Ti bolt, 32.6mm
- Our highest grade, exclusive S-Works SL4 FACT 11r carbon frame is equal parts stiff, responsive, compliant, and smooth thanks in part to its compact race design and the vibration damping Zertz inserts.
- The Specialized FACT carbon fork comes in three different sizes with varying steerer diameters that optimize stiffness for that size, while also providing excellent steering response. Road chatter is also absorbed through the Zertz elastomer inserts.
- The Roval Rapide CLX 40 Disc wheels combine all the rapid acceleration and lightweight performance that you'd expect from a top-end carbon wheelset with the versatility of being disc-specific, while Ceramic Speed bearings set everything over the top to be the ultimate in wheel performance.
