Selling the below two bikes. Let me know if interested. I have a full slew of pictures for both bikes ready to send to interested parties.
Shipping included in price and prices are assuming friends and family payment.
Specialized Stumpjumper Evo 650b (2015; Lage; $2600 shipped)
Size Large
This bike is an amazing all around bike with a killer build package. It does everything excellent and is very fun to ride. Rear shock was just services by suspension experts in NC which makes the bike so smooth. Overall in excellent condition, 2 little nicks which have been touched up and almost everything has been covered in clear film to protect. I will get picks of the few blemishes but nothing even noticeable. X01 1x11, Carbon SRAM cranks, XT brakes brand new Nobby Nic EVO pacestar rear and brand new Bontrager XR4 team issue both set up tubeless. This bike has less then 500 miles and best of all, it's a very rare color! This color was only available as a bare frame. Price is negotiable just make me an offer.
FRAME
FACT 9m carbon, EVO 650b geometry, FACT IS construction, FACT carbon front triangle, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, ISCG ’05, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 150mm travel
REAR SHOCK
Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and rebound adjust, 194x51mm
FORK
RockShox Pike RC 650b, Solo Air spring, tapered alloy steerer, w/ compression, rebound adjust, 15mm thru-axle, 150mm travel
STEM
Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS
Specialized All-Mountain, low rise bar, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS
Specialized Sip Grip, light lock-on
FRONT BRAKE
Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, S/M: 180mm rotor, Others: 200mm
REAR BRAKE
Shimano XT BR-M785, hydraulic disc, Ice Tech metallic pads, S/M: 160mm rotor, Others: 180mm
BRAKE LEVERS
Shimano XT BL-M785, hydraulic, alloy lever
REAR DERAILLEUR
SRAM GX, 11-speed
SHIFT LEVERS
SRAM X01, 11-speed, trigger
CASSETTE
SRAM XG-1195, 11-speed, 10-42
CHAIN
SRAM PC-X1, 11-speed
CRANKSET
Custom SRAM S-2200, carbon, PF30 spindle, 30T, 94mm BCD spider
BOTTOM BRACKET
SRAM, PF30, OS press-in bearings, sealed cartridge
RIMS
Roval Traverse 650b, alloy disc, 24mm wide, 27/32h
FRONT TIRE
Bontrager XR4 Team issue 27.5x2.35
REAR TIRE
Nobby Nic EVO pacestar 27.5x2.25
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST
Command Post IR, 3-position height adjustable, alien head design, bottom mount cable routing, w/ remote adjust standard lever, 30.9mm, 125mm
All setup tubeless. Needs a new rear thru axle. The head fell off. Need to use pliers to get off currently, but it is serviceable. I can arrange getting one ordered and shipped to you if the purchase hinges on it.
Niner BSB Cross Bike (56; $1400 shipped)
Selling my Niner BSB size 56cm.
White/blue colorway
100 x15 front
Quick release rear
SRAM rival 1x hydro
Rear is set up as 10 speed as the hubs can't be easily upgraded to 11 l. Just one extra click at the top of the range. Worked fine this way
Stans grail rims set up tubeless
Only damage to note is marks to crankset and scrapping on non drivetrain side from a slide out in muddy race last year.
Full compliment of pictures on request with detail shots.
Size Large
FRAME
REAR SHOCK
FORK
STEM
HANDLEBARS
GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
REAR DERAILLEUR
SRAM GX, 11-speed
SHIFT LEVERS
CASSETTE
CHAIN
CRANKSET
BOTTOM BRACKET
RIMS
FRONT TIRE
REAR TIRE
SADDLE
SEATPOST
White/blue colorway
100 x15 front
Quick release rear
SRAM rival 1x hydro
