Re: 3-hole (SPD-SL) Midfoot cleat position.. [fastsi]
you are looking at either a custom shoe or some modification to existing shoes as far as I know. Google search should bring up some modification how to.
My Blog - http://leegoocrap.blogspot.com
Re: 3-hole (SPD-SL) Midfoot cleat position.. [leegoocrap]
I was hoping that somebody had a hack to solve this :-) To avoid the expensive custom solution.. Thanks for the reply
One thing I've done is modify the Shimano SPD-SL bolt heads. I took a file and removed material to reduce the circumference of the button head bolt to add an extra 5mm or so of adjustment (I was looking to get them a little farther back). Now it won't necessarily get you to mid-foot but closer depending on your shoe.
My LBS has special bolts inserts that they use to modify shoes. So it does exist out there
Francois-Xavier Li @FrancoisLi
"We don't stop playing because we grow old; we grow old because we stop playing." George Bernard Shaw
http://www.swimrunfrance.fr
http://www.worldofswimrun.com
Re: 3-hole (SPD-SL) Midfoot cleat position.. [Fix]
Will you let me know of the name and contact info for your LBS?
old thread here:
http://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/Who_has_drilled_in_carbon_soles_to_bring_cleats_backwards%3F_P3581814/?search_string=nickag%20bont#p3581814
My Bonts which are 6-7 years old have a relatively flat base to the sole and allow the cleats to be moved a long way back. Bont actually install the cleat nuts with T-nuts, all you have to do is drill another set of holes further back on the sole and move the T-nuts.
fastsi wrote:
Will you let me know of the name and contact info for your LBS?http://www.tri1st.co.uk/
You can EMail 'Damo' and mention me (Fix)
Thank you. You are a godsend, Fix
fastsi wrote:
Thank you. You are a godsend, FixFrancois-Xavier Li @FrancoisLi
Haha, just spoke with a guy from the LBS and he were very helpful and willing to help me.! I enyv you for having such a great LBS near you :-)
