svennn wrote:
Can anyone measure the width at the nose and maybe a few cm back from the tip?
That's harder than it sounds because of the curves. I'd say it's slightly under 50mm at the first bit of the nose that is close to horizontal. Then it gets gradually wider. So at, for instance, 5 cm back it's about 55mm wide. I'd have to find my calipers to be more accurate. Happy to mark up a screenshot if you think that would help?
I really like the firmness of it. Certainly not hard and it never feels like you use up all the give and are sitting on something solid.
I'm not sure it's my perfect saddle but it is a very good one. I'm experimenting with position at the moment and I needed something to try. At the moment my bike geometry and position are the limitations rather than the saddle itself.
