From what I have always heard, it has to do with building code and the region of the USA that the building is built in. Basements are more common in areas that get cold because the foundation has to go down lower than the level of ground freeze. Since the foundation is already is being dug down low, the cost of adding on the additional digging/work for the basement is minimal relative to the added property value that a basement may bring in living and storage space. I would guess this is the case even in areas of a high water table.
I am not a builder and do not know building code, so that may be total BS, but it is what I have been told a few times.
so why do you even have basements in any area where there's likely to be permanent or even seasonal ground water?
Quote:
Just a question from afar as there are very few houses in Australia with basements.... so why do you even have basements in any area where there's likely to be permanent or even seasonal ground water?
