Are those Crocs! Awesome!!!
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [johnnybefit]
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [GreenPlease]
Oh yes, search the article archives here for him. He is really amazing and bike and runs in crocs! Efraim Manzano.
EDIT: http://www.slowtwitch.com/Interview/Meet_Crocs_man_Efraim_Manzano_j3169.html
Enjoy! John
Enjoy! John
johnnybefit: Aug 27, 16 18:05
Carbon-fiber crocs on a aluminum base. Velcro with locating pin. There is a mating hole drilled in the shoe bottom.
You can actually have two positions on the shoe if you want, eg. forward and mid, depending on how your calves are feeling that day. The locating pin can be moved easily as well. I was doing bricks that day :)
Training Tweets: https://twitter.com/Jagersport_com
FM Sports: http://fluidmotionsports.com
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [SharkFM]
That is kinda unique, and cool. How are those if your pulling up? do they hold the shoe?
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [devashish_paul]
This makes no sense. Clipless pedals keep your feet where they need to be, and allow you use the full range of muscles.
'It never gets easier, you just get crazier.'
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [georged]
georged wrote:
This makes no sense. Clipless pedals keep your feet where they need to be, and allow you use the full range of muscles.I wouldn't race in something that made me slower. In point form:
- I have greater range because the stack is zero
- lower stack means lower saddle height = more aero. More room behind the bars too. I call this cockpit space.
- very light, very aero with the underside cover
- organic connection allows for some mojo vs a locked-in feel (ie mistracking)
- operates very close to my Look and Crank bros pedals.
-run in and out of transition no probs.
-Once bed in (takes about 6-10 pedal strokes), pulling up is not an issue. You have to twist out just like the Looks - which I find is kinda crazy it works like that.
This is my very first set ever made, flawless performance, including top bike split (not AG - the whole field).
So I wanted to try your idea. I took some old Sidi tri shoes I had and cut off the heel tab, so that just the heel collar remains.
Took them out on a test ride yesterday and they work great. Much easier to get into/out of. My heel moves a little, but was able to do uphill sprints no problem.
ECMGN Therapy Silicon Valley:
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [Thomas Gerlach]
I'm running LA84s with the tongues cut out and quick laces. They're really good for long, hot rides where I'm dumping a lot of ice on myself, because I can change to dry socks quickly and easily. I pull up in them, but it is really enough back and up when I'm making power and just an unweighting straight up. My feet don't move.
It is a really great idea and thanks Thomas.
Re: My Thomas Gerlach Inspired Short-Course Cycling Shoes [jon.isom]
jon.isom wrote:
I'm running LA84s with the tongues cut out and quick laces. They're really good for long, hot rides where I'm dumping a lot of ice on myself, because I can change to dry socks quickly and easily. I pull up in them, but it is really enough back and up when I'm making power and just an unweighting straight up. My feet don't move. It is a really great idea and thanks Thomas.
Glad to be able to help - thanks for the kind words :)
Can anyone remark on the stiffness of these? I noticed they have a nylon soles. These would be used for heavy road training.
I have a pair I use for road. They are not as stiff as my carbon sidis, but studies have shown that there is no power loss, even with much flexier shoes (there's a gcn video on this).
The LGs are lighter than my sidis due to the lack of buckles and boas, and more aero. The only downside is the higher stack height (2mm) due to the thicker nylon sole.
