Classifieds
Re: F.S. FSA Gossamer crankset 165mm 53/39T 130BCD MegaExo [engi]
If they are still available I will take them!
Still available, bump.
Not sure this would fit my bike but I have an older cervelo p1(2006) i believe its a megaEXO but the crank itself says ISISdrive...how can i tell the specs for such an old bike. lookin to get shorter cranks.
Re: F.S. FSA Gossamer crankset 165mm 53/39T 130BCD MegaExo [espejo09]
espejo09 wrote:
Not sure this would fit my bike but I have an older cervelo p1(2006) i believe its a megaEXO but the crank itself says ISISdrive...how can i tell the specs for such an old bike. lookin to get shorter cranks.The ISIS is a dual-side splined Shimano BB for standard threaded BB shells with "inboard" bearings. FSA MegaExo, Shimano HollowTech and SRAM/Truvativ GXP are also threaded bottom brackets but with outboard bearing cups (hence, effectively stiffer due to wider bearing spacing). MegaExo and HollowTech use a 24mm diameter spindle, while GXP is a 22mm.
Take a look at your bike in the BB area and see if there are black/silver/gold/whatever colored discs on both sides of the BB shell. If there are, you have (possibly) a MegaExo BB. The discs should look like this:
Having said all this, I have a spare MegaExo BB that I'll be happy to throw in with purchase. Just under 2K miles on it, and the bearings still spin smooth.
Sorry, image isn't coming through
Let me get your email I'll send it through there
espejo09 wrote:
Let me get your email I'll send it through therePM sent
I will take them if first deal falls through! Scott
