Anachronism wrote:
DFW_Tri wrote:
You bought a used wheel with a crack in it, the crack is getting worse, and that is a knock on HED wheel?? That could describe any wheel and is a little unfair don't you think?
There are new cracks forming where there where not cracks before. I have handled the wheels with a reasonable amount of care. Not acceptable to me but I honestly described the situation, others can decide for themselves. Personally I would prefer a stronger fairing at the expense of a few grams extra weight.
If these are intended to be a super fragile race wheel that require extra delicate care then as an answer to the op they are certainly not appropriate for everyday use.
Edit - personally I find it unfair to only read half of someone's post before making a snarky comment, but again, people can decide for themselves.
I have a set of HED Jet6+ Blacks that I've put over 5K miles on of every day use (they reside on my road bike) and neither of the carbon caps have any sort of damage or cracks.
In fact, the rear rim has even suffered pothole damage (I was able to repair the bead dent by gently bending it back - try THAT with an all-carbon clincher!), and both wheels were on board when I crashed back in May hard enough to fracture my pelvis (over the bars at 30 mph after a rider in front of me slid out and went down in a corner). The only "crash damage" was the rear wheel being slightly out of true, which was easily remedied. Despite all that, they look and perform just like brand new.
So, IME, they are not "super fragile race wheels" and are just fine for everyday use. If you have cracks forming, you might want to review just how careful you actually are being with handling them...or, contact Hed and find out if that may be an issue they're aware of. Perhaps it was a batch issue.
BTW, I've previously owned a set of Hed Jet 9s which are of the same construction, and never had any cracks in the caps on those either...
