WD Pro wrote:
Just a question, why should a super bike be anymore 'fickle' (component wise) than a more basic bike with the same or lesser components ? Does the engineering get worse the more you pay ... ? WD :-)
I'll give you one example....the rear brake which is typically hidden and harder to service on "superbikes"....at least it is on my P4. I'm always fiddling with it as it has little clearance but when it's adjusted right it works fine....I don't mind it to get the more advanced engineering as opposed to the typical rear brake set up on a "more basic bike". Engineering not "worse"....just more complicated. To the OP, good luck with the claim....but I'd invest a little more time and money if needed. The bike has a great reputation and you will probably take a pretty good hit if you elect to sell. Again, good luck.
