Quote:
the 3t also have a good pull ratio for use with omegas.
I'm surprised that you feel that way. I've now ridden off course twice due to the switch from SRAM's S990 (which I highly recommend). However, I am on the original Omega (gen 1) and have found that the Omega X is much, much better than the GEN1. I complained to Nick about flex on the Gen1 cable hanger, but he dismissed my concern; however, in the redesign the cable hanger was beefed up a lot.
With the S990s I could go in much hotter into turns than I can with the 3Ts, but I won't be switching anytime soon. That being said if you like good brakes the levers will have an impact and the SRAM S990s did well for me there. Also the SRAMs have a barrel adjuster built in to the lever, which makes getting cable tension easy and or when switching wheels (wide to narrow).
Also agree that the return spring on the 3T is not an issue if you have good cable routing.
My YouTubes
