zander1976 wrote:
Good Morning, I am very new to triathlons and I have a race tomorrow. What is the best race pressure for Cont attack/force 24mm/22mm tires at on HED Jet 6 Black. I weigh 80kg or 175lb and based on this chart I should run 120psi in the front at 105psi in the rear. Is that correct? Also, should I switch from attack/force to 25mm GP4000s on a Cervelo P5? Looking at a different chart gave my 110 and 95 for front and rear. Very confusing.
Thank you,
Ben
Unless I missed it being mentioned, that chart was for Michelin Pro4 or Pro3 tires. Michelin used to include it with their tire packaging. Unless your tires have the same TPI, I wouldn't use it for other brands. Even so, I think it's a bit high. I'm 205 lbs and ride my Michelins at 105 front and 110 rear on "standard" width rims. I reduce that based on the rim width. I'm way too damn lazy to figure the correct pressure based on weight and volume, so I just guess. For my Flo 60's, I use 95 front and 100 rear.
hah
edited to add, I still ride 23mm tires.
FatandSlow: Sep 8, 17 8:43
