Striker213 wrote:
I’m just curious how thick everyone’s skin is in terms of cycling in heavy winds, and how often that influences you canceling a cycling workout for that particular day when you look at a weather report.
I assume everyone is comfortable with a 10 mile per hour headwind, and/or a 15 mile per hour crosswind.
If you brave stronger conditions:
1) What are the max headwind/crosswind speeds you ride in?
2) How far does your average speed drop?
For me, it would be a function of the workout intensity and duration. I live in Conejo Valley (Ventura County in Southern California). We get some wicked winds, especially on Santa Ana days. Before that, lived in Penticton, BC which was at least as windy, likely more so.
If it's a long ride or a hard ride, no amount of wind will force me inside or make me cancel. I've ridden in countless wind advisories. I figure it's good Kona practice. But if it's a very short and easy ride, and it's blowing a gale, I might just hop on the trainer instead. Especially since we get much more head/tail (because of the shape of the valleys) than cross, it's kind of hard to go for an easy ride when you are granny gearing it into the wind at a huge effort and spinning out your biggest gear with the tailwind.
Simply put, if the workout makes it overly challenging to achieve the objective of your ride, then find an alternative. In almost every case, I'd say what that means is if the wind makes it too hard to ride as EASY as you want, do something else. If the wind is going to make the hard part of your workout more challenging? HTFU...
