Nicko wrote:
Ummm, no. Now you are completely mixing up rolling resistance (that scales with vertical load) with the topic at hand, the "non-measured" aerodynamic property called "power to spin" (that scales with air speed).
Completely different entities. Like Crr and CdA. Try again.
And your textbook graphs deals with slip and slip angles in relation to horizontal forces that are 0-100% of the vertical load.
In the case of "power to spin", the force that is required for that is ~0.04% of the vertical load.
There will be no significant slip, and yes, there will be a horizontal force that actually "spins" the wheel.
I thought the diagram represented real world conditions not "wheel in the tunnel driven by a roller" conditions. In that case, the horizontal force between the roller and the tire that counteracts the aerodynamic and bearing resisting moments can only be generated if some slip is present.
http://cds-0.blogspot.com
