grumpier.mike wrote:
endosch2 wrote:
I would try to pick up some Hed Jet 6 or 6/9 on sale, you can find them for 1000 to 1200 new. They are aero as anything, same weight wise, and you dont have to deal with the crappy braking and brake pad switch hassle of carbon clinchers. No hub recalls, the list goes on and on why they make the most sense. I know Hed does not have the marketing power of others but they are great all around wheels.
+1
HED just makes great wheels that are not as flashy as full carbon. You can't go wrong here.
I have owned the Flo 60s, 30s, and FC 404s. Cross wind performance of the 404s is noticably better. To the best of my knowledge the cfd design process Flo uses probably doesn't allow them to do much in terms designing for crosswind stability.
Actually, CFD allows you to do a lot in terms of crosswind stability. It was actually on of the design criteria in the algorithm used to design our new wheel line. Zipps are a heck of a lot lighter than the Flo 60s. My 404s weigh about 35grams less than my Flo 30s.
If you are talking about the old FLO 60s then yes. That said, our new Carbon Clincher FLO 60s are 121g lighter than the Zipp FC 404. The FC 404's weigh in at 1690g and our FLO 60 CC weigh in at 1569g. Zipp also has a warranty where you will replace damaged rims for a reasonable price. Unless Flo has changed recently, your warranty option is to buy a new wheel.
We work with customers on damaged rims all of the time. Our new wheel line gives us even more flexibility with this. Out of curiosity, what is the price to replace a damaged Zipp rim? The numbers I've seen are very close to our original prices, which means you are essentially getting their distributor pricing. Don't get me wrong, Flo makes a nice wheel, it's just that the Zipps are better in my opinion. You doget what you pay for. You just have to decide if the price premium is worth it to you.
If you shop carefully you can sometimes find them pretty cheap. My 404s were 1600$ with a new PT G3 laced in.
Chris Thornham
Co-Founder And Previous Owner Of FLO Cycling
