Grant.Reuter wrote:
nightfend wrote:
chaparral wrote:
nightfend wrote:
Do a 20 or 60 minute ftp test with your Stages powermeter, and then use that new number as your baseline. Your Stages reading lower isn't really a problem if you base all your training around this new set of numbers.Well, unless your balance changes the longer you are in a zone (which there is evidence for lots of people), or balance changes day to day (once again evidence), or over time if your balance changes since you are getting feedback from the left leg and to make your number bigger all you need to do is press harder with the left leg.
Sure, but the guy already owns the Stages powermeter. He still needs to start somewhere. Your suggestion is for him to just scrap his purchase and start over and that is not very helpful.
Yes starting somewhere is getting rid of something that will give you bad input data and getting something that will give you good input data. He could also train for a few years with junk data and not achieve as much as he wants to. If you're buying a PM to actually improve your cycling then get a powermeter that will give you that data to do so. Don't just go buy one for the sake of saying you now have a powermeter. The good data is what gives you the ability to structure workouts that will achieve better gains than biking around hard all the time.
I think it's a little extreme to say it's totally junk data and is unusable. Maybe I'm leaving huge gobs of power on the table because my training is less than optimal. I simply don't believe that. Should he consider selling it and upgrading sometimes soon, sure? But... front door brag warning here.... i kicked the ass of a lot of folks on the Big Island back in October with far better bikes, wheels, helmets, fancy nutrition, expensive coaches, high end power meters, you name it all over Kona in October. I don't even think I had that great of a build in terms of volume, trained less than the year before and was 5lbs heavier. It didn't matter... until I hit the run at least.
I have the same issue with my Stages. I'm either the most aerodynamic triathlete on the planet for my size, or my left leg is stronger... or a little of both. There's no fixing it. All power meters vary somewhat, so you really need to use threshold power tested on that bike with that power meter and set your zones accordingly. Unless your doing aero testing, the accuracy isn't important. Although there is the issue of variability between L/R balance over time and at varying power levels.
I'm still waiting for a better powermeter to show up on my doorstep. Until then I work around what I have and still consider it far better than heart rate for training, pacing and tracking training load.
Should the OP have bought a Stages? Probably not for the reason above. But he's stuck with it now, so unless he has a deep well of funds, it can be utilized to provide adequate data for training with power. Taking care of "low hanging fruit", doesn't require a high level of precision.
TrainingBible Coaching
http://www.trainingbible.com
motoguy128: Apr 29, 16 5:47
