Rbk_3 wrote:
So I signed up just to reply to this thread.
I have what I believe is OP but just want some clarification. I believe it started last summer from cycling and drastically increasing my intensity from 0 KM to 2000km and 25kph average to 32kph average in 6 weeks on a bike with a saddle 2-3cm too high (confirmed after I completed a bike fit hoping to solve the issue. I also had my saddle pressure mapped and it came back nearly perfect, no soft tissue pressure)
On the bike I was fine, no pain, but after and especially at night I had an extremely dull ache coming from the center of my pubic bone area. Resting for a week or so would make the pain pretty much go away, but when I returned the same dull ache came back. By the time I stopped cycling, I had really did myself in and the dull ache lasted for weeks before it started to subside a little. I continued to play basketball through the fall, and while it doesn’t flair me up like the cycling, I think it is slowing the healing process.
In February I was feeling 80% better, not so much a pain anymore, but always sort of had a discomfort, especially when sitting at work for long periods. I went for a short 20 minute training ride and bam, the pain returned in full and I was back at square one.
So in late March I decided to buy a recumbent bike to try and keep up my fitness thinking it would solve the issue, but nope, same problem. I think the pedal motion flairs it up.
Does this sound at all like OP? I have an X-ray coming up. Initially I wasn’t sure where the pain was coming from exactly, I just knew deep in my perineum.I thought it was perhaps nerve related but a pelvic floor physio visit ruled that out. Then after this latest ride I pushed hard on my pubic syphisis area and it is very tender and produces a sharp pain when pressed.
I haven’t found any real results of people getting this from cycling. But based on the criteria I think rapidly increasing intensity on a bike with a saddle that was too high, with no stretching prior and pretty poor form may have been the contributing factors that caused it.
Sorry to read about all of your trouble. As you mentioned, OP is usually associated with running or rugby, and not cycling. I was able to cycle with zero issues but NO running or swimming. To me, this definitely sounds like OP. But, the pain in the public symphysis can be referred from other area too, so get checked by your doc to make sure you do not have a hernia (not sports hernia but an inguinal hernia).
As far as an X-ray is concerned, it may not help very much with your diagnosis because the problem with OP is inflammation in the bone or damage to nearby muscles. My pelvic X-ray was normal so I had to get an MRI to demonstrate the edema in the pubic symphysis. Once other possible causes (i.e., hernia) are ruled out, you will most likely need an MRI for confirmatory diagnosis.
As far as your activity goes, I would avoid anything that exacerbates the problem. For now, no cycling, running, or basketball. Anything that requires jumping, leaping, or lateral movements is most likely going to irritate your condition.
Please make sure you have a thorough evaluation by a sports med doctor. Once you have confirmation of OP, then start work with physio. Best of luck!
