How to stop my P2 (2015) seatpost from slipping?
I did a search. Seems there's no lack of folks with seatposts slipping on Cervelos, but I didn't see a thread that addressed the new(est) clamping method they're utilizing.
My LBS has put the gritty grease (I have no idea what it actually is) on the seatpost. I mark it with electrical tape (even tried building it up with a layer of tape) and it does no good. It'll be back to a lower position in a ride or two.
I'm battling runner's knee..............and this seatpost is a PITA (and knee). What can I do about it?
Thanks.
Re: How to stop my P2 (2015) seatpost from slipping? [nc452010] [ In reply to ]
had this issue with my 2012 cervelo p3. mechanic put some loctite in the screw. problem solved.
Re: How to stop my P2 (2015) seatpost from slipping? [ghostrocket] [ In reply to ]
Semi related story... I went to a local lbs and told them I had a problem with the seat post slipping. The mechanic said he usually wiped his hand on the shop floor to pick up some dirt and would rub it on the seat post. I watched him very closely while he worked on my bike that day and never went back.
Brad
3SIXTY5cycling.com
I had a similar situation on my Venge, no amount of fiber grip helped, even exceeded torque spec after a talk with my specialized rep and it still slipped. They finally said it was a known issue and replaced the post with a later edition. Try contacting customer service and see what they say.
Jim
**Note above poster works for a retailer selling bikes and related gear*
Take the seatpost out. Get a can of Aqua Net super hold hair spray. Spray that sucker down GOOD, and re-install it before it dries.
Bam, no slip.
Another thing I've heard of doing is creating shims out of an aluminum can or foil, and stuffing down there. Good luck!
Re: How to stop my P2 (2015) seatpost from slipping? [nickwhite] [ In reply to ]
if doing thr shim method with aluminum can scrap, make sure you use fiber grip on both sides od the can to avoid corrosion
Is there play between the post and tube? I used a small amount of epoxy on a friends tube to build up a little from he insertion point down. Then sanded and used carbon paste and it never slipped again.
Try putting loctite on the seat-post itself. I use this method when I build a prosthesis that uses a carbon pylon in a tube clamp, slippage problems disappear.
Sell it. I'm on my second seat post in 4 years.
Did you buy the bike new from an authorized Cervelo dealer? Did you register the bike? If so, I've found Cervelo customer service to be very responsive. I'd call them directly instead of emailing for faster service to get a recommended solution. They provided me with a new seat post for my four year old P4 recently. Maybe just a simple warranty issue.
Thanks.
I'm assuming that everything is being tightened to a torque spec (8nm, which is higher than most think), grease is being applied to the wedge bolt and mechanism, and the assembly paste is being used....?
If not that, time to get to race weight! (just kidding, but the above represents my recommendations)
Re: How to stop my P2 (2015) seatpost from slipping? [James Haycraft] [ In reply to ]
8Nm? yeah, no clue it was that high, I do 4 without issue
and why are we responding to t thread from Feb??
Re: How to stop my P2 (2015) seatpost from slipping? [jeffp] [ In reply to ]
one of the only useful things in the cervelo owner's manuals is the torque specs. pretty sure it's 8. also, didn't realize thread was old. now i feel like a lemming
x2....never noticed. But, torque spec on mine is 10 yet it cracked at 8.7 using my new topeak digital.....after 4 years of tightening by hand with no issues. Go figure.
Does it help to play some Whitesnake or Dokken in the background at the same time?
Although it's a different mechanism, I had issues with this on my 2012 P3. I actually stripped the socket by over-tightening and had to have my LBS drill it out and install a new, slightly wider "stint" of sorts. Needless to say I am very careful tightening down this bolt now. The solution I've found is to cut two squares of aluminum out of a coke can or something and use them as shims on the side of my seat post. I have electrical tape on my seat post where it enters the frame that doubles to mark my correct saddle height and holds the two pieces of aluminum in place. It's not elegant, and I'm annoyed that I have to do it, but it's simple and it works.
On my 2012 P2, it says "max 4nm" on the seatpost clamp. I always tighten it to 4 and have never had a slip issue since the bike was new.
Re: How to stop my P2 (2015) seatpost from slipping? [jpk_phx] [ In reply to ]
you have a different seatpost clamp.
On my 2010 P2 the solution that worked for me was folded up aluminum baking foil around the very front of the post together with Tacx carbon assembly compound on the seat post.
