FS: Brand new Rotor cranks, 165mm arms, round aero chaining
New, never used Rotor 3d+ crankset. 165mm crank arms, 130bcd 53T round (NoQ) aero chaining, 39t small ring. $450 plus shipping obo
Re: Brand new Rotor cranks, 165mm arms, round aero chaining [Russ Brandt] [ In reply to ]
still for sale
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [Russ Brandt] [ In reply to ]
10 speed or 11 speed
BTW, that's a 30mm axle diameter for those that asked
bump
I'd give you $175 you might want to revise your asking price as they are not the same cranks as other rotor cranks...
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [YTZ] [ In reply to ]
Please explain???
Maybe there is something I am missing but this crankset is not brand new in the sense that it is this years model, but new that it has never been used. AFAIK, Rotor updates the logo and printing on the chainrings and arms from time to time, but very little substantially changes in the actual product. What I do know for sure is that the aero chainring alone is worth almost $200. I just bought a set of new Rotor crankarms only for $300. If I need to recalibrate my pricing I'm all for it if there is sufficient evidence I'm way off.
bump
these are becoming harder and harder to find. Make this yours!
still available
Just found buried in my garage!
I can do $50 plus shipping without the chain rings?
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [trifantasy] [ In reply to ]
Thanks for the offer but I'll pass.
would you sell it without the chainrings? if so how much
Yes, I'd sell the crankset without the chainrings. The arms and spindle would be $250
What bottom bracket does this use?
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [mkng1] [ In reply to ]
3d+ is bb30 I believe but please consult Rotor website to confirm.
FYI that is the bbright lockring and spider.
The spindles on these are 30mm diameter, but the spindle is longer than a bb30 spindle and make it able to fit a lot of frames (much like bb386evo). the lockring and spider on this one will limit that a bit, as it will not fit anything with outboard bearings or cups. on most setups these require conical 11.3 or 11.5mm spacers to be used. The lockring and spider on this one have the drive side spacer built into it already.
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [wiRIDEfast] [ In reply to ]
In other words, that spider won't fit a true BB386 frame. As set up, that crank will only fit PF30 and BB30 with the 11.5mm spacer or BBRight with no spacer. With a new (smaller) lockring it will fit a BSA30 (threaded) setup. With a new (smaller) lockring and narrower spider, it will fit a true BB386 frame.
The asking price is hilarious.
Re: FS: Brand new Rotor cranks, 165mm arms, round aero chaining [dangle] [ In reply to ]
I may be off on price, all I know is what I paid for it. However, if this is a unicorn and someone wants it, I'm a reasonable guy and certainly willing to work on the price (but would rather let it sit in my garage than entertain an absurd low ball offer). What I do know is that chainrings are chainrings and Rotor 165 crank arms are sometimes desired when experimenting with different lengths, this set will supply both for a lot less than if buying new from retail.
