We posted an article on ERO Insight about this, though it really isn't about the FC35, per se, we simply use it as an example. Still, I think a lot of you might be interested in the numbers, so here's a quick overview:
Jim Manton / ERO Sports
- The FC35 can give you nice aero gain, upwards of 8+ watts, but only if you set it up correctly; the mount is the key.
- Instead of installing the mount right side up, turn it upside down and mount it under the extensions instead. The lower mounting position brings the bottle down nicely between the extensions, and provides a significant aero gain. If you mount it right side up, there's likely to be an aero penalty as it sits too high and increases your frontal area.
- It also looks to be important to slide the FC35 back as much as possible (we find this true of most systems). Bump it right up against the stem.
