Seller Description
Well maintained 2012 Size Large Scott Plasma 10, with top of the line and durable Dura-Ace components. Professionally tuned with fresh tires installed. Extras include Shimano 105 pedals, Cee Gees Cushy�s Aerobar Pads, Profile Design T4 Carbon J-bend Aerobar Extensions, Dark Speed Works Speedpack and Speedfill BTA bottle cage. Better than new and ready to roll. Asking:$1,000
Factory Description
Scott's Plasma 10 takes aerodynamics and speed to a whole new level. Every tube on this carbon beauty is shaped to maximize speed and reduce air drag to help you smash personal bests. Furthering that mission is the integrated fork, ultra-narrow chainstays, integrated cable routing and frame cutouts that shield the wheels from the wind. To make sure you're aerodynamic, too, you get a Profile stem, brake levers and aerobars that let you find the perfect, most powerful position possible. You'll also love the rest of the kit, such as the speedy Shimano wheels, world-class Shimano Dura-Ace drivetrain, Fizik triathlon seat, Continental tires (seller note: replaced with Zipp Tangente) and Dura-Ace bar-end shifters, all of which are sure to take your racing to the next level.
Specifications
Weight
8.4kg / 18.5lbs
Frame
SCOTT Plasma 2
IMP technology / HMF-NET
TRI Geometry
Plasma 2 seatpost
Replaceable hanger
Fork
Scott Plasma 2
1 1/8" carbon
Integrated
Headset
Ritchey PRO Integrated
45mm drop- in headset
Derailleur (Rear)
Shimano Dura Ace RD-7900
20 Speed
Derailleur (Front)
Shimano Dura Ace FD-7900
Shifters
Dura-Ace SL-BS 79 Bar End
Brake Levers
Profile ABS Semi Carbon
Brakes
FSA SL-K
Lightweight, dual pivot design
Crankset
FSA SL-K Light MegaExo
39/53
BB-Set
FSA BB-8681, 68mm
Handlebar
Profile OZERO
Aerobar
Profile T4 Carbon+ Cobra
H'stem
Profile Legra
1-1/8" - 31,8mm - 80�
Pedals
Shimano 105 PD-5700 SPD SL
Seatpost
Plasma 2 with Ritchey WCS adjustable head
Seat
Fizik Arione TRI 2
Hub (Front)
Shimano WH-R501 black
Hub (Rear)
Chain
Shimano CN-6701
Cassette
Shimano CS-6700 / 10 speed
11-25
Spokes
Shimano WH-R501-30 black
Rims
16 Front / 20 Rear
Tires
Zipp Tangente Clincher / 700 x 21
Factory Description
Specifications
Weight
8.4kg / 18.5lbs
Frame
SCOTT Plasma 2
TRI Geometry
Plasma 2 seatpost
Replaceable hanger
Fork
Scott Plasma 2
1 1/8" carbon
Integrated
Headset
Derailleur (Rear)
20 Speed
Derailleur (Front)
Shifters
Brake Levers
Brakes
FSA SL-K
Crankset
39/53
BB-Set
FSA BB-8681, 68mm
Handlebar
Profile OZERO
Aerobar
H'stem
Profile Legra
Pedals
Seatpost
Seat
Fizik Arione TRI 2
Hub (Front)
Hub (Rear)
Chain
Shimano CN-6701
Cassette
11-25
Spokes
Rims
16 Front / 20 Rear
Tires
GreatScott: Jun 12, 19 17:23
