i have recently installed Osymetric chain rings and wanted to fi d out if this will affect my fit. I feel a little pain in my knee during a workout that was not here before. should i try to get a tweak or maybe its just a transition period and the pain will disappear. thanx for any advice in advance .
Fitters
Re: OSYMETRIC AND FIT [Pawlikny]
no pushing a bigger gear thru the power phase. more pressure on knees than before.
rings do not affect fit coordinates.
Retul Certified Fitter. gebioMized Pressure Mapping http://www.PedPowerPerformLab.com.
Retailer of Wahoo Fitness, Sable Water Optics, Enve Composit, Giro and more.
Zone3 USA Ambassador - use code DEAN25 for 25% off
http://www.OasisOne-Twelve.com - The ultimate hands free hydration system.
https://www.athlinks.com/athletes/19354499 - results.
Re: OSYMETRIC AND FIT [hideano]
That makes sense , but apparently studies have shown that osymetric rings will have around 15% less stress on knees than regular ones . That's confusing
thru the back side (partial reduction of the dead spot) less stress but now pushing more teeth thru the power phase
They won't affect your fit but their effectiveness is dependent upon the fit. If you sit further aft or forward of how the rings were made, you won't see the full benefit of the ring's ovalization. This is where Rotor Q-Rings shine--they are adjustable based on your fit. Osymmetric from what I understand, are not.
Brian Grasky
Grasky Endurance: World Championship Triathlon Coaching; Professional Training Camps
RETUL fitter, Biomechanist, USAT Level 3 Coach, USAC Level 2 Coach
Brian Grasky
Here in France we have a lot of cyclists with O'Sym and most of them need to be 2 to 5 mm higher on the saddle with the O'Sym (if they were at the good position before of course).
And they must think to keep a good RPM.
Joel Steve
Fitter for the French Triathlon Federation
Fitter for Arkea Samsic Pro Cycling Team
Fitter for AG2R Pro Cycling Team
Joel Steve
Osymmetric chain rings require a different muscle activation pattern. Chances are likely that your glute(s) aren't activating and instead, you're using the quads to do most of the work. You might need a slightly shorter crank length to let the knee recover and practice your glute activation, but once you're consistent, you should be able to go back to the original crank with no issues.
http://www.eatsleeptrainsmart.com/...ing-you-need-to.html
Vincent Vergara
Eat.Sleep.Train Smart - Personal Training & Coaching
EatSleepTrainSmart.com
Twitter: @ESTrainSmart
Strava: app.strava.com/athletes/444535
Vincent Vergara
