Nobody has yet demonstrated clearly that wide matters anywhere. You dropped pressure to 85-90 and it got comfy. You can do that on a less wide rim too. In fact you should achieve the same comfort on a less wide rim at a slightly higher pressure.
For what its worth... Ive been running 85-90psi in both sets of wheels on that bike. Its taken really rough roads and taken quite a bit of the edge off of them, so its easier to stay in the bars. I run 16.5cm of drop, so being able to stay stable is pretty important.
Im trying to decide now if the standard Jet 23mm (more economical) disc is a better choice, or should I hold out for a 25mm disc. Does the wide matter as much in the rear? Enve doesn't think so...
secondchancepro wrote:
I have a 2014 Cervelo P2. I have raced HED Jet6+ wheels several times with GP4000 23mm tires with no fit issues at all. Im mounting 25mm tires on my Ardennes+ wheels today and will ride later today. I'll report back if I have any issues. I don't think I will. Ton of room in there. For what its worth... Ive been running 85-90psi in both sets of wheels on that bike. Its taken really rough roads and taken quite a bit of the edge off of them, so its easier to stay in the bars. I run 16.5cm of drop, so being able to stay stable is pretty important.
