devashish_paul wrote:
Larbot wrote:
rruff wrote:
The difference between a powertap and a quarq will not be a constant number, but most closely simply a percentage of power at that point in time. 5% diffference is probably reasonable. When this has been tested in the lab, drivetrain losses are closer to a fixed wattage for the range you are interested in (like 150-500W). And it is ~8W if your gear is in good condition.
I have tested 2 different powertaps vs 2 different cranks (SRM, QUARQ), on the road @ ~250 watts (all properly calibrated and zeroed).
In both cases, the crank-based watts were 2-3 watts higher.
Wow, 2-3 watts seems pretty good. I thought it was in the range of 5-8. But this also reminds of why Mirinda Carfrae has a big penalty vs. Caroline Steffen. Mirinda has to put out the exact same watts to overcome her drivetrain, and she has to put out the he exact same watts to turn her 700 wheels at 36 kph. The watts to overcome her drivetrain and the watts to overcome the wheels are a higher percentage of her overall brute power output. Definitely pays to be a bigger rider in Kona where watts per kilo are not that big deal and where brute top line watts matter more. The run is a different story though!
Which makes the accomplishments of a mini-imp like Emma Pooley really stand out as superb.
Hugh
Genetics load the gun, lifestyle pulls the trigger.
