ccomg I've fit half a dozen women like this over the years, some were custom some were not. Right now I'm dealing with a lady even smaller than what Dan is proposing here.
Creepy, though, I'm 5'5" and my saddle height is 635.....so I'm totally biased here because I know how I ride. Or I am burdened by my own bias, as a fitter, working with ladies of similar stature. But you guys don't have that problem fitting guys similarly proportioned to yourselves??? That's another thread.
Seat angle: better to keep her shallower, someone this small will only weight 45-50kg, so power to weight is commensurate. Let her utilise those hams and glutes to the fullest extent, not compromise power output to accommodate reach.
Let me also point out that, as we are fitting a person who will be racing, under USA Cycling rules, the nose of the saddle must be at least 5cm behind the BB center.
I work with a DFU, so I setup my machine here to mimic Dan's proposed dimensions. My seat angle is actually shallower, and I knew she's be 'off the charts' when I typed numbers into the machine for the X/Y. However, my saddle nose is 70mm behind BB.
When I calculate Stack/Reach she is off the charts, but I expected that once I saw the numbers on the machine.
Per Dan's comment: "...i ask whether the driver in bike fit is to find a comfortable, powerful position; or to find a position underneath which sits a choice of available production bikes" Then I have to say yes to comfort and power, but you better know your mechanical limits. I can 'make' you fit just about any bike I have here in the store, trust me. I have certainly 'fixed' customers who were sold bikes under this model, and who's to argue the difference between a 54 with a 110 stem and a 56 with a 90 stem?
Back to Dan's Problem Lady:
Looking at it, I say 'way too much drop', it's measuring at 85mm. She may want the 'racer' look, but that much hip to hand drop is better for the track. She will be better balance if her Y is at 590 or 600.
Overall reach to bar center isn't too crazy, but I'd pay attention to what bar dimension I'm using as well as what shifter brand is preferred. The nose of saddle to shifter 'tip' measurement is 610cm.
Anne Barnes
ABBikefit, Ltd
FIST/SICI/FIST DOWN DEEP
X/Y Coordinator
abbikefit@gmail.com
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
