kiki wrote:
This is probably wishful thinking, but I've got a toe/foot issue (probably sesamoiditis, don't think it's an actual fracture) that's been going on for a couple weeks. Mild discomfort with walking, actually less with running, as long as I keep the big toe relaxed through the stride. I've got the toe taped to its buddy next door to minimize movement.
I don't want to go to the doctor because thanks to previous concerns, I've been misdiagnosed repeatedly. I really don't want to be told to stop running for another 6 weeks as a default solution. Stubborn!
My question is, has anyone here successfully trained through a minor injury (of whatever kind), or in your experience, has continuing to train only made it much worse? Thank You!
Is running your main sport? Does it hurt with cycling?
I can tell you I Always recommend laying off if something is hurting in the way your are describing. If you are conscious about your running stride while running and trying to ensure that this or that is relaxed to avoid the pain, I can almost guarantee you that you are changing something else in your run as well. It might be small, but over miles and miles, it can add up to another injury. Also the difference between an inflammation and a stress fracture is usually just time. I have run shin splints into stress fractures - TWICE! I can understand the frustration of mis-diagnosis. If you can (either financially or if your insurance pays for it) go to a sports physical therapist in your area. PT's and Orthopedic Surgeons test almost equivalently at their knowledge and expertise of the musculoskeletal injury. There is always a chance that something may be mis-diagnosed. But I hate to say it, I would guess the larger part of your fear is as you stated...you don't want to be told not to run.
So what are some alternatives?
Water running - reduces the stress on the body
Anti-gravity treadmill - to reduce stress
cycle more if there is no pain
Have your shoe wear re-evaluated (by more than the running shoe guy - PT, DPM, etc)
If triathlon is your main thing - working on the bike (assuming it doesn't hurt) will actually help your run. In all but maybe the sprint distance, over biking often cooks people for the run. Having the opportunity to work on the biking leg may actually yield great race results while letting the foot rest.
Good luck. Sometimes the old saying "if it hurts don't do it" applies - I think this is one of those cases.
________________________________________________
Don't Just Live, Thrive!
Thrive Kinematics Physical Therapy -
http://www.facebook.com/...8178667572974?ref=hl
