I posted this at BT yesterday and if you're not in and would like to chime in, I'd appreciate it. First, please read the whole thread because I think my posts might answer some questions. Here's my last response:
"(quote from Yanti)
The value of properly-fitting bike shorts can't be overestimated. For one thing, if they are skin-tight and worn that way (as they should be) they will hold your labia together so that your clitoris won't even touch the fabric. If there's any pressure or friction, it'll be borne by the far-less sensitive labia that have a fat layer underneath. With the properly fitting shorts, pressure from the saddle will actually cause the lips to hold tighter together, not spread apart to expose the clitoris."
My response:
Ok, now this is something I was pondering on today's ride and thank you SO MUCH for being so specific. After switching to my DH's stem and saddle from the Bontrager, I realized that "normal" for me was to feel public bones rolling over soft tissue constantly and once I got on DH's saddle I no longer felt the rolling/movement. Today I spent most of 40 km in aero and was shocked to find no open sores when I got home. That is a first for me. I did first Desitin, then chamois buttr and then vaseline and just before I left I added more ChamoisButtr. I was sure it was Too Much but I wanted to be able to put the "not enough lube" thought to rest. I've always thought I used enough but today I was certain. I am also sure that part of the problem is the raised nose on the Bontrager.
HOWEVER, I have to ride on my right
ischium (note, not the ischial tuberosity that i'm on in non-aero) and cannot side directly straight on the saddle without much pain, and I was wondering today if it is normal to have you labia open up when sitting directly on the saddle as mine ALWAYS *feel* open. I usually get out of the saddle then and try to get things to shift back together but once I sit down again I'm back to square one, so off I sit on the side in order to be able to sit in aero.
I was CERTAIN my shorts were tight enough but thanks to your post, Yanti, I know they certainly can't be. Is this the case with everyone? Noone has their labia open ohen in aero? That would make SUCH a huge difference in comfort, I'd imagine. Again, thanks everyone."
Some pictures from yesterday. I was trying to relax my lower back which put my head higher and I did have shoulder strain. I did not have short bagging up but on the way back (20 km out and back, our bread-and-butter ride) I was getting bunching on the left inner groin crease (noticeable as I'd chafed there previously trying to make position adjustments. I was swimming in Vaseline yesterday). I'm actually not certain how well these represent my position as I remembered remarking to Jamie that once we started riding again (after taking pictures) my position felt different from the picture ones, but maybe these will help. Seat tube turned 180 degrees, seat forward (will try the measurement you describe later today Kivisisalik) and using my husband's saddle (no bump on the nose).
http://harvestmoon6.blogspot.com https://www.caringbridge.org/visit/katasmit
