It has been widely reported that the average rate of return on SS "contributions" is about 2%. Compared to historical inflation rates that is actually a net negative ROI. Compare SS to the Federal Employee's Thrift Savings Plan:
(1) There are five funds from which employees can chose to invest in. The three most popular are the "G" or government securities, "F" which is basically a money market/bond fund, and the "C" which is a common stock fund. The average rates of return from 1988 through 2003 for these funds were: "G" 6.78%, "F" 8.05%, and "C" 13.64%. The "G" fund has never had a negative annual rate of return. The "F" fund has had two years of negative returns, and the "C" has had four. Pro-SS argument--What if the stock market goes down? Answer--You can see, based on the average TSP rates of return and the historical performance of the stock market that this argument is basically a bogus scare tactic.
(2) You can choose to invest all or any portion of up to 10% of your earnings in any mixture of the five funds. I contribute 50% to the "G" fund and 50% to the "C" fund. Fund balances or contributions can be moved between funds online. Pro-SS argument--People do not know hpw to invest. Answer--Given the limited options available, the TSP is basically dummy-proof. You could also set up some restrictions such as setting minimum age-based percentages that must be invested in low-risk funds.
(3) When I retire I can start drawing an immediate annuity or roll over my balance into another qualified plan. If I die before I draw out all my balance, my heirs will get the balance as opposed to SS which ends when I die.
(4) My contributions are non-taxable, and will be taxed when I start drawing an annuity, presumably at a lower marginal rate.
Why wouldn't the general populace DEMAND that the government replace SS with a plan such as this?
