Bobby Sweeting wrote:
Your three main variables are wheel speed, motor power input, and brake caliper force. Two should be controlled and the third measured. Our engineers felt as though it would be most accurate and easily understood if we controlled power input and caliper force. It would have also been very difficult for us to create a setup with variable caliper loading, considering that we don't have unlimited time and budget for pressure transducers and the like, haha. My only point was that, regardless of the test setup, the results table at the end of the video will show the rims in the same order. Hopefully another brand will take all of this to heart and do their own testing with a different setup, and we'll definitely submit a rim!You're insistent on this, you're kind of making me wonder whether I'm missing something. Let's take an extreme case: Wheel 1 has a Teflon coating, so it takes a huge amount of brake caliper force to yield an equivalent amount of actual braking. Wheel 2 is super sticky, so it requires far less brake caliper force. In your test, Wheel 1 is going to crush Wheel 2, because way less heat gets generated. But in the real world, a rider would have to brake way harder to achieve the same descent speeds on Wheel 1, so the test sheds no light on whether Wheel 1 would be more likely to make it down a given mountain. Someone suggested above that in the initial test results your wheels ran about 1 mph faster than other wheels. If that's true, your wheel is Wheel 1 in the example above, and your test tells me nothing about your wheel's ability to safety make it down mountain X. It might be safer, or it might be less safe, but we just don't know based on the test. Clearer?
