3t arduro in p3c
Anyone done it or familiar w the bar? Iļø have done the top tube mod and am most curious about cable routing and rear brake routing with magura brakes. Iļø am currently running aura pro bar with a sigma stem but want to go lower.
Re: 3t arduro in p3c [Climbcmb] [ In reply to ]
An Aduro (I assume that's what you mean) wouldn't get you lower. You need a -25 + low stack bar and you can get quite a bit lower. To route Magura brakes through P3c you have to drill out the top tube cable entry/exit points a bit.
aduro is 60mm stack min from steer tube to lowest pad stack. additionally, if your holes in toptube are where the aduro routes internally, then you run the rick of sheering the magura brake line as the p3c has no steer tube stop for the fork and turning too far will cut the lines/kink cables/sheet di2(here is where etap would not get hit :) if you dont have holes drilled where aduro exit is, then you need holes in top of stem plate so cables not routed as aerodynamically as possible. also, if you want really narrow, the aduro needs tweaking.
